Old 4th May 2014, 01:44 PM
Cheers Guy.
Will have a look tomorrow and see if I can tell if it is that.
Where should the rear drains end ?
On a D3 they end half way up around the seat side of the wheel arch Andy
Old 4th May 2014, 03:37 PM
gninnam gninnam is offline
Cheer Niel.
Just being chaufered in the wife's D2 and ve4y nice it is
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 4th May 2014, 04:16 PM
Norretal's Avatar
Norretal Norretal is offline
Cheer Niel.
I've only been chauffeured in my D2 a few times but it's very enjoyable, usually in the front passenger seat though, you two fallen out?
Audi TT - 2015 - Ultra
Old 4th May 2014, 04:18 PM
- Nah, just fancied a change
Andy.
Current cars:
BMW i4 M-Sport
Old 4th May 2014, 04:30 PM
Norretal's Avatar
I hope you grasped the opportunity to look intelligent and give everyone you passed a wrist type wave?
Old 5th May 2014, 04:17 PM
Nope - I'm to cool for that
Anywho - jacked the car up, opened the sunroof and poured some water into the sunroof channels and water can out of both the front and rear drains in good quantities so it looks like the pipes are good.
Andy.
Current cars:
BMW i4 M-Sport
Old 5th May 2014, 05:03 PM
I'm jealous, I haven't been chaufered in my 8 yet, probably because no one is allowed to drive it, especially Mrs.
Any way
Looks like next thing to check is the fuel/lpg cap as its very close to where you found the water.
I'm sure you/we will get to the bottom of it so you can keep the car.
As soon source is found focus can go to electronic components coz they will drain battery if even slightly water damaged.
Did you checked the battery management module, how does it look, any signs of water/corrosion on it??
Old 5th May 2014, 05:53 PM
Cheers Marcin
Is a nice place to be in, the back of an A8 - do recommend giving it a go
Will look at the filler tomorrow!
And hope you are right (thanks again)
Andy.
Current cars:
BMW i4 M-Sport
Old 5th May 2014, 09:50 PM
Hmmm. A sad read indeed. I wonder whats going on with it......
Defo need to find the source of the leak before attempting to fix anything. You suggest that water is coming in good quantities - which is good - it should make it easier to troubleshoot.
I had a nightmare with an A2 a while back, its sunroof drains had blocked and all the water had run down the headlining into the boot. Totally soaked the carpets and boot area, floor carpet, back seats. Took forever and them some to dry out the dam thing, but now, with clear drains and dried interior its good as new. For a long time I thought I hadn't fixed the leak, but it turned out to be the same water evaporating and condensing on the windows time and time again. A good few sunny days with the windows left down and the moisture escaped....
In terms of troubleshooting your car I can only state the obvious - water flows downhill, so if its in the battery compartment, it came from above, somewhere. Also, my driveway is flattish as you know, and I never had any such issues, I wonder if you regularly park it at some angle that triggers an issue I never saw ?
I also agree with others about the plastic window trims - They are purely cosmetic, the window is bonded beyond that.
The LPG filler is an obvious "aftermarket" addition, but the D3 flap seals quite well iirc, so I dont really see what would have changed to make it suddenly leak in.....
I hope you get it sorted....
Old 5th May 2014, 10:34 PM
Cheers Ian - not good is it
The drive is at an angle, but most of the time it is in the garage, but when it wasn't used for around 5 weeks it was on the drive..............
Roof lining and carpets are bone dry - the only area that is suspect is the LPG filler so I will look to put some silicon or something like that around the area.
When I wash the car and open the flap it is full of water!
Andy.
Current cars:
BMW i4 M-Sport
