Old 28th October 2014, 09:39 PM
I thought A8 links were a lot longer, I didn't realise you would need to cut down the steel ball links. The Czech ebay picture seems to show them not cut down. Is it the 40valve engine?
http://i1217.photobucket.com/albums/...1299429626.jpg
Another option may be one of these male threaded ones and one of the female threaded ones, then hopefully no threading needed just cut the threaded one down to size?
http://www.ebay.co.uk/itm/Kart-1-x-8...item4adb384c76
http://www.ebay.co.uk/itm/Track-Rod-...item4d256c42a8
There are even aluminium alloy ones which would be easier to tap if deeper threading was needed. I may actually go for some of these for my current car. The previous buyer got my fixed up S8.
http://www.ebay.co.uk/itm/L800-M8-8m...item3cc0090445
Old 29th October 2014, 07:41 AM
There are 1" and 2" links, depending on the engine.
IIRC the S8 engines use 1", the rest 2" as the manifold is different.
Old 29th October 2014, 08:17 AM
That's what I thought. 1" only on S8's so I don't understand why Borys is trying to fit short ones if 2" ones are needed. Lets better check this before he puts too short arms.
Borys, what's the engine on your car?? (W12??)
Old 31st October 2014, 06:03 AM
Just to clarify something.
All D3s have 1" non whatsoever are 2" arms the difference between 1" and 2" was d2 a8 and d2 s8
D3 3.7 and 4.2 are all 1" arms as is the S8 V10
Old 31st October 2014, 06:12 AM
Strangely i have a contact in the casting world that would produce the arms in plastic or metal/ally but the minimum order is 500 of them ! And i was thinking about selling them but its costly
Old 31st October 2014, 06:43 AM
Borys's Avatar
Borys Borys is offline
1" for sure, took original out, measured it before ordering
Thanx guys
Old 31st October 2014, 08:35 AM
WRONG!!!
Don't know about V10, but 3.7 and 4.2 are 2" Guy
http://forum.a8parts.co.uk/showthread.php?t=8252&page=3
Old 31st October 2014, 08:41 AM
I recently stripped a 3.7 to fix it and 2 4.2 and they were all 1"
Ma8 maybe some one fitted incorrect ones to your car before you bought it ?
Or the 3.7 i worked on was incorrect ...4.2 is definitely 1" 100%
3.7 now im not so sure
The S8 V10 is electronic the V8s are vac pods
Old 31st October 2014, 08:45 AM
No mate, 1" would not the reach the vac pod, plus Ollie on his 3.7 had 2" as well, so two cars with wrong parts? Don't think so
And if they would reach the vac pod then both flaps would stay half open at all times
Old 31st October 2014, 09:26 AM
Borys's Avatar
I will say it again
I did remove the original linkage from the car, mesaured it and it is 1"
Both of them
