Old 7th July 2015, 05:43 PM
Bathtowel23 Bathtowel23 is offline
Exclamation Bubbling on boot lid
Hi I seem to have some bubbling of the paint on my boot lid right at the licence plate lights was just wondering will this be covered in the cars bodywork warranty.does anyone know how many years bodywork warranty the a8 comes with. Thanks guys
Old 7th July 2015, 07:54 PM
Conquistador's Avatar
How old is your A8? I believe it's 3 years from the date the vehicle was first registered. An Audi dealer should carry out the repairs free (as long as it's not caused by an accident or poor care etc.) even if you didn't buy the car from them.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 8th July 2015, 08:02 AM
Three years for paint, 12 for the bodywork.
In either case it is subject to the car having not been re-pained outside of an Audi Approved body shop.
https://www.audi.co.uk/owners-area/a...onditions.html
Old 8th July 2015, 08:59 AM
Mine was the same but not visible unless crouching.
I just had to replace this part with the reversing camera version and I doubt my paint is as strong as the factory, so will have to watch out for this.
My 2006 A8 is bubbling around both from indicator repeaters which I will sort out on Friday.
Old 11th July 2015, 11:45 AM
Cheers snapdragon. Whereabouts did you buy your boot lid part and was it expensive??
Old 11th July 2015, 12:32 PM
It was from Trade Parts Specialist (TPS) and was about £140 plus say £10 for the gasket and a sealing strip.
Sorry to mislead you, I have had a look at the old A8 part and the only bubbling is around the tail light screw holes, maybe caused by galvanic reaction with the steel screws? The bubbling is hidden by the lights so was no problem.
If yours is really bad and you need a new one, you can have it for ~£4-5 postage cost, but it would need repainting and I did drill 2 extra small holes on the underside that would need filling and sanding. It also has 2 of the tail light screws seized in
Old 5th August 2015, 09:45 PM
madcjd madcjd is offline
I have the same issue. On the n/s of that panel - right above the license plate light.
I took it to Aylebury Audi to see if it was covered under warranty ( mine's an October 2005). They took plenty of pics, sent them off, but......it came back as a not covered issue, even though, I've seen several other D3s with this same defect.
Will eventually get round to sorting it as it quite 'unsightly'!
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
Old 6th August 2015, 08:46 AM
Upon closer inspection of the old part, it is clearly galvanic reaction emanating from the screws that hold the number plate lights on (and often seize in place).
I used nylon screws on my new lights. M3x12 from ebay china and put a smal drop of plastic-freindly oil on the threads as they tend to grab a bit and the head is a bit soft.
http://www.ebay.co.uk/itm/151711761449
Old 7th August 2015, 08:30 PM
Joe2.0E Joe2.0E is offline
I had the same issue on a 2004 car. I managed to get a sucessful warranty claim through my local dealer in 2012. I had a full Audi Service History at the time.
The small black triangles on the rear side windows were also done at the same time, I've seen both on a lot of D3's. Should have been a recall or TSB.
Maybe try another dealer ?
