Old 30th July 2015, 12:58 PM
ahd91 ahd91 is offline
Default S8 FL Harsh Ride
So now that the car is working again, I can get on to resolving its other issues.
Recently (I think) the car's ride seems to have become quite harsh, and I'm not sure if this coincided with two new tyres and a tyre rotation that I had a month ago.
Now it does have the 20" alloys, so I'm not expecting to float down the road, but I feel like every bump can be felt, and there's a lot of road noise that comes up into the cabin on most roads that aren't smooth. Sometimes it can jolt over larger dips in the road, though it never feels unstable or loose. I'm running at 40psi all round as suggested by several on here - I'm not sure if lowering this by 4-5psi is a) going to make any difference, b) going to put the alloys at risk.
What should I be looking for/are there any known suspension weak spots?
Old 30th July 2015, 01:14 PM
I can only relate my limited experience. My current S8 felt harsh similar to what you describe, and it had FE 20's and on top of that had some cheap aftermarket harsh front springs.
I had correct factory springs put back on and 18" wheels, and it felt normal again just like my previous S8, comfortable but firm and stable, not wallowy.
The 18's run on 32psi, but that's with 245 45 tyres.
Old 30th July 2015, 01:15 PM
36psi is the standard pressure.
If you want a chart for the fuel flap print this at the right scale and laminate it:
Old 30th July 2015, 01:18 PM
I'd have a guess at either poor quality tyres and/or front suspension arm wear.
I've had similar symptoms from both.
Old 30th July 2015, 01:43 PM
I do love this forum - instant help!
Yes, I've got the numbers on the inside of the filler cap but general consensus seemed to be 40. Will try at 36 and see what things are like.
Springs are factory, and control arms did appear to look good the last time I was down there but I'll have a better look.
Old 30th July 2015, 01:47 PM
What make are the tyres?
Old 30th July 2015, 02:36 PM
They're P Zeros all round, though the front two are a few mm more worn than the back.
