Old 15th August 2015, 01:59 PM
Borys's Avatar
Borys Borys is offline
Default Bluetooth question
Seems my 8 is loosing my phone?
Each time I come back to the car need to pair the phone again
Any ideas?
Thanx
Old 15th August 2015, 02:50 PM
Hello, do you mean re-pair or reconnect?
Do you have to type a code in again?
If you leave the phone in the house (out of range) and go back to the car is your phone's name still listed in the menu?
Are you running the latest firmwares in the MMI?
Old 15th August 2015, 03:33 PM
Borys's Avatar
I meant I need to reconnect with pairing code
I just got the car so no clue which firmware in mmi
I don't see my name on screen really.....probably I did something wrong with setting all up
Old 15th August 2015, 04:09 PM
If you're on Android phone you sometimes need to go into your paired devices and tell it to remember the paired connection. If all else fails delete the connection and start again
Think I have the mmi firmware update discs if it does need an update
Old 15th August 2015, 04:39 PM
Borys's Avatar
Will try to delete
Pair, set up all again
Adrian we are nearly neighbours your help would be appriciated :-)
Will let you know
Thanx
Old 15th August 2015, 06:57 PM
No probs - am away this week but around from next weekend
