Old 17th August 2015, 12:23 PM
Sir WIll Sir WIll is offline
Default D2 Climate is Grumpy
Ladies and Gents,
I have noticed an odd problem with the climate in the D2. On occasion on a hot day I can get in the car the climate ramps the fans up behind the dash.
Trouble is the dash vents only seem to be outputting a level of air equivalent to a fly sneezing.
I then stop, turn off and turn on again.
Everything starts the fans ramp up and if by magic plenty of air is now blowing out the vents?
Thoughts?
Old 18th August 2015, 04:32 PM
B@fink B@fink is offline
Is the cabin temp sensor thingy full of fluff? That might convince it not to blow out of cabin vents? Quite why off and on would make it start is beyond me.
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound.
Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting.
Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids
Old 18th August 2015, 08:23 PM
Are you perhaps suffering from sticky flaps?
I'll rephrase that ...
I'm thinking maybe a flap or two is sticking in the 'home' position, perhaps due to a sticky mechanism or failing motor.
Old 29th August 2015, 01:32 PM
Hoovered all the sensors in the cabin and had a good look at everything.
Basically the cabin air intake under the bonnet is not opening, if I remove the flaps on it plenty of air pulled into the cabin.
Time to charge the laptop and get VAGCOM on it and run through the climate settings.
Old 29th August 2015, 05:45 PM
Yep now the motor is reporting a fault on VAGCOM.
Time to buy a 4D0820511A off eBay.
