Old 14th October 2015, 01:05 PM
iGO iGO is offline
Default RPM fluctuation
Hi everyone
I bought my A8L 2000 4.2 three weeks ago.
Since then I experiencing RPM fluctuation around 40mph. Computer scan didn't showed any errors.
Maybe someone had same issue or have any ideas what reason of fault.
Thanks for help
Igor
Old 14th October 2015, 01:46 PM
Conquistador's Avatar
Gearbox? Old boxes which haven't been recently serviced sometimes make the revs flutter between 4th and 5th gear.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 14th October 2015, 02:03 PM
or possibly have you checked the operation of the 2 bellows under the bonnet when somebody starts the car to make sure that the manifold flaps are operating and not sticking?
Old 14th October 2015, 02:15 PM
iGO iGO is offline
I remember, mechanic told me last time, that one of intake manifold links broken.
Old 14th October 2015, 04:01 PM
in that case it will affect the variable manifold intake at the other stages to where the flap is stuck/broken at. Probably a good idea to get it refurbed / fixed or you would risk more damage if anything else broke up in there.
Old 17th October 2015, 09:55 AM
ChrisG's Avatar
ChrisG ChrisG is offline
This is odd because my car has a similar issue, but its in all gears and at any range.
The issue I have seen goes like this.
Take foot off the gas, the car slows down as normal - RPM are smooth
Put you foot down hard, car engages fine, the RPM's engage and stay locked.
If you are driving along, and as with any A8 you are hovering at a low RPM, and you put you foot down a little, you hear the engine RPM rise, but then, as it tries to keep going, there almost seems to be a clutch slip, the RPM jumps, then engages again.
In addition, if you are trying to maintain a speed - 30, or 40, you will see the RPM need jumping 200rpm ever so often.
This isnt a massive issue for me, but it can be irritating. It only seems to happen when the cars at low RPM. The worst one is when you are stuck in 50mph contraflows on the motorway. Cars in 5th, and right at the lower end of the gear, and it just sit there jumping. Change to tip mode and put it in 4th seems to be the only solution.
I had thought it was the Torque converter on the box that was causing this.
Old 8th July 2016, 07:25 PM
iGO iGO is offline
After trans oil and filter change RPM fluctuation still appears
