Old 1st November 2015, 09:13 PM
sparksuk's Avatar
sparksuk sparksuk is offline
Default HVAC issue
Hello guys. I did a scan today because the heating does not work properly and i don't really know from where to start to look for the fault. I have attached a photo. Any ideea ?
Old 3rd November 2015, 06:54 AM
mannyo mannyo is offline
The control module is the part with the dials and buttons, maybe worth removing and checking the connections are all good.
I have a HVAC fault on mine, but the error in my case relates to the blower controller under the bonnet, and the fault mentions this.
Manny
Past
Old 3rd November 2015, 08:34 AM
Not sure about that code Spark , clear it down do the full systems test with the vcds see if anything comes up , i think first place i would be looking is the water control valve to the side of the pollen filter housing , with engine running feel the pipes going from the engine to the valve , see if the pipes are hot past the valve toward the heater matix , could be the valve stuck closed or could be blocked matrix radiator , are both drivers and pasenger sides not getting warm or is one better than the other .
May seem like a daft question .......the water level is ok ??
Old 5th November 2015, 04:14 PM
sparksuk's Avatar
The problem is : if the heating is over 23 celsius, no heating goes in the back on the pillars and on the one in the middle back. Only goes on the blower under the front seats. Also on the windscreen, the driver side is still cold air but on the passenger side is warm. Strange.
The water level is ok. Where exactly is placed those valves ? Underneath dash on the passenger side ? Is a box with a filter there ( cabin or polen filter ). Is it easy acces, can i remove that and check it properly ?
Thsnks
Old 5th November 2015, 06:02 PM
The valves are under the scuttle panel in the engine bay, the pollen filter is also there.
Open bonnet,
remove rubber trim that runs across the engine bay near the screen.
Lift out both halves of the plastic scuttle covers.
The Pollen filter is under the cover in the centre
The valves are located on the UK passenger side of that centre box, you'll see them with the cover removed.
The rear footwell vents are electrically heated due to the distance from the heater box.
The valves look like the link.
http://www.wolfautoparts.com/4e09596...bly-63759.html
Manny
Past
Old 5th November 2015, 09:35 PM
sparksuk's Avatar
Thank you in this case it look like an mechanical problem ? Thing is, the cold air (ac ) goes in the back but not the hot air. Or it may be an issue with that valves. I belive is bit difficult to take the whole thing out of there and check them. well, if i know for sure thats the problem i will just replace it. the most anoying thing is when i have to defrost or demist the windscreen, one side ( driver ) blows cold air and the other side is warm.
Also i manage to activate with Vag the additional aux heating !! thanks to this forum, i found all the informations how to do it )
