Old 4th November 2015, 01:19 PM
Professor Peach's Avatar
Default What is this?
So I had to swap my battery on the old girl this week and when I removed the old one, I found this in the battery 'well'.
What is it? It has an Audi logo on it, so I'm assuming part of the car .
Name:	Rubber Thing.JPG
2016 S3 Sportback
Old 4th November 2015, 01:25 PM
...it looks a bit like one of the drain plugs for the aircon thingy in the transmission tunnel....
2016 S3 Sportback
Old 4th November 2015, 01:30 PM
definitely looks like a drain bung of some sort - not seen one off the car, but looks similar to the ones on our A6 that i had to clear in the bulkhead area.
I found some missing trim fittings from the boot side panel under the battery when I changed mine....
Old 4th November 2015, 02:32 PM
It's definitely the 'teat' from the scuttle drain that fits in the wheel arch.
Old 4th November 2015, 03:18 PM
Yup, I concur. It's the squeezy rubber nipply thing that normally lives under the front wheel arch. I have 2 exactly the same on my workbench right now that I pulled off my car a few months ago ... haven't gotten around to refitting them yet.
Old 4th November 2015, 03:25 PM
So, not essential that I dash outside and re-fit immediately then!
Cheers folks.
2016 S3 Sportback
Old 4th November 2015, 03:37 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I can't quite tell from the pic, have you maybe got a bigger photo, that would be easier to see😉
2007 Mini Cooper S R56
Old 4th November 2015, 03:54 PM
I tried embedding directly into the post (whereas normally I'd add a link to a hosting site) as I'd recently read it worked on this site (HPSauce posted it up). I may not do it again, as it is a tad on the large side!
Name:	Rubber Thing Big.jpg
2016 S3 Sportback
Old 4th November 2015, 03:57 PM
You just need a larger monitor John
Matt
Old 4th November 2015, 04:01 PM
Johnmed's Avatar
Ha Matt and Prof Peach!!! I'm projecting it onto my neighbours' house right now and I can just about make it out😳
Is it a drainage doodah?
