Thread Tools
Display Modes
My D3 has the factory motorola kit, with the SIM card in the console and separate handset. I always use it hands free, so never really bothered with the handset. The handset only ever comes into play when showing people the car, its more of a gimmick as the driver cannot use it.
Move forward to today, I was cleaning the interior when I lift up the armrest and see that the handset has split into two pieces. it look like the clips holding it together have failed with age. Handset still works fine, except now its split apart and the cheap chinese battery I put in also needs replacing as its charge was not 100% after taking lifting out the handset. Battery has not expanded or anything, whats happened is weird, never seen anything like it. Now to superglue the poor thing back together, and hope it holds.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 12th December 2015 at 12:39 PM. |
still trying to find the good use for mine... and ideally it would have been good that I had a Bluetooth so as to connect the phone tight away and use if for A2DP streaming
![]() If you are interested drop me a note as I may be able to decomm the stuff from my car and replace with BT... hence the parts will be up for grabs ![]() |
I actually don't mind having a different number in the car. I have an O2 PayG sim card, and I just call forward from my iPhone to the car when I am driving so no need for real BT. For music I use AMI with a 500GB HD plugged in so don't need A2DP either.
I've found a brand new one on eBay, but it dates from 2004 looking at the date on the battery but I am going for the superglue first and see what happens.
