Old 24th December 2015, 01:23 PM
CR51GYR-A8 CR51GYR-A8 is offline
Default Fuel pressure fault code, what do we think? Code inside.
Here's the code that popped up.
Still the same issue when flooring it the glow plug light pops up. What could be the fault here?
I don't think my fuel filter has been changed so I've ordered one of those. As I've read it could be that or a fuel leak somewhere? Or a dpf block?
I want to remove my dpf and I will be loosing the cats and everything with a remap aswell. But obviously this fault needs to go beforehand.
Any ideas?
Old 24th December 2015, 01:30 PM
To change fuel filter was going to be my first suggestion.
Old 24th December 2015, 04:21 PM
Yeah il grab one. I've gone to Audi but there closed so couldn't order one.
Where else will have one off the shelf over Xmas.
Old 24th December 2015, 04:50 PM
tipptop tipptop is offline
Fuel leak or pumps dodgy or injector(s) dodgy or possibly partially blocked filter if your lucky.
http://audiforum.us/threads/004195-f...tdi-bug.16141/
Look for obvious leaks first. Good luck!
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 24th December 2015, 07:50 PM
Burnzybubbles's Avatar
If it's a 3.0tdi then it could well be excessive leak back from injectors.
Old 24th December 2015, 09:45 PM
Euro Car Parts or GSF
Old 25th December 2015, 05:17 PM
voicey voicey is offline
TDI right?
My first step would be to perform a leak off test on the injectors (as suggested above).
The fuel rail should have an over pressure relief valve - do a leak off test on the return from this as well as they can start to open which causes the pressure in the fuel rail to drop.
Do you know how the fuel pump pressure is regulated? The last diesel I had used a valve to regulate the pressure - these can go faulty. I would monitor the solenoid that controls the valve using a decent diagnostic tool.
Old 25th December 2015, 05:44 PM
Originally Posted by voicey View Post
TDI right?
How do I perform that test then on the injectors?
Old 25th December 2015, 08:25 PM
Look on leak off tests on the Internet, regardless of car it'll be the same principle, next would be finding the recommended values, but a deviation of over 10% between injectors would flag a problem.
There is also documented VCDS tests for injector health, I can't remember where it is but its out there.
I can't remember the setup for the HP pump, guessing it'll be a FMV on the pump controlling the pressure to the rail.
Old 3rd January 2016, 01:50 PM
This was the fuel filter. Happy days......
