Old 7th January 2016, 03:27 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Towbar fitting
How did all.
I have an OEM towbar, swan neck and generic electric kit. I'm not too hot with electrics, but I've got help on hand.
I've read something about a worm gear, is that something I need to be aware of?
And how do I get hold of a wiring diagram?
Thanks in advance.
2007 Mini Cooper S R56
Old 7th January 2016, 03:33 PM
Hi John. Are you connecting the electrics to module J345 Trailer detector control unit?
Matt
Old 7th January 2016, 03:37 PM
Johnmed's Avatar
Hi Matt. Is that installed on the car already? If not, no. Using a bypass relay. Not ideal, but needs must. The mechanical install is my area, the electrical side will be the brother in laws!
Old 7th January 2016, 03:41 PM
Johnmed's Avatar
Is that the box I saw under my battery Matt?
Old 7th January 2016, 03:42 PM
I'm not sure if that module was standard equipment. It's located under the battery... (of all places!) Having said that it's probably easier to wire in a generic system.
The wiring can be found in Del's D3 Tech Dump, item 2 Current flow
Matt
Old 7th January 2016, 03:44 PM
Probably. it's made by Westfalia, part 4E0907383(rev)
Matt
Johnmed's Avatar
I'm with you now Matt. Thanks very much. Again.
