Old 10th January 2016, 10:36 AM
CrozA8's Avatar
CrozA8 CrozA8 is offline
Default D3 serviceable shock bits
Hi All,
I am having trouble finding the info I need about my leaking left front shock on my 2006 D3 A8.
The leak is coming from the brass inlet valve on the side of the shock(see photo). My question is "are these bits serviceable"? I would really hate to replace the shock be it recon/second hand if all that was required were a few o-rings.
I know the info would be on here somewhere but being new here I am having navigational jitters.
Any help greatly appreciated.
Old 10th January 2016, 02:35 PM
It's not a common problem. Where is it leaking? Where two different colour metals seal?
Old 10th January 2016, 02:37 PM
mannyo mannyo is offline
As far as I am aware there are no end user serviceable parts. if air is leaking from where you say it could just be a side effect of air leaking from the bag and escaping where you see it.
You can buy refurbished parts from the likes of Arnott rather than OEM if you need to save a few dollars.
Manny
Past
Old 10th January 2016, 02:56 PM
I'm afraid your only real route of repair is a replacement, the brass fitting is secured from the inside and it's unlikely you can get to it withoutif stripping the strut down which is not a good idea without the experience or equipment the like of the supplier will have.
Old 10th January 2016, 03:17 PM
If you are in Queensland then WW Shock Absorbers in Brisbane do reconditioning. Its worth a call.
Old 10th January 2016, 10:39 PM
CrozA8's Avatar
Default D3 sevicable shock bits
Gentleman,
Thank you for your replies. The news is as suspected.
WW shockers are not answering but thanks for the tip David.
I think I will canvas the dismantling yards for a replacement and pray.
Regards
Old 11th January 2016, 06:28 AM
Borys's Avatar
Borys Borys is offline
Use airdominance 300£ per referb shock with warranty, you need to give your as exchange so defo they can be fixed
Old 11th January 2016, 11:44 AM
CrozA8's Avatar
Default D3 Servicable shock bits
Many thanks Boris. It seems there are so many options on you side of the world. I have spent the afternoon here looking for second hand parts with absolutely no luck whatsoever.
Enquiry sent to Airdominace for quote.
Thankyou
Chris.
Old 11th January 2016, 12:21 PM
Borys's Avatar
Sorry mate just saw your location :-)
Didn't pay attention
Old 11th January 2016, 09:24 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
That brass part on the Touareg is serviceable.
Unblot and bolt new in, we had to make a tool to do the job, but it worked.
The end of that part looks like a bolt head?
What does etka say?
I've stripped down a couple of all road shocks easily, I got no idea what the A8s are like.
But don't put slime in the bags, it don't work.
[center]
06 3.0TDI Quattro:
Options:
