Old 30th July 2009, 09:56 AM
A8, mate!
Guest
Posts: n/a
Default Which Phatnoise?
I know these can be fitted to an '8, but the ones I have seen for sale are not advertised as fitting it. They list A3, A4 A6 and TT I think. So are there different versions? Which do I need for a D2 FL nav equipped car?
Thanks.
Old 30th July 2009, 06:30 PM
as long as it's a vag phatbox it'll work. You may need to flash the firmware if it's came from another car.
Also, you may need a different adapter cable. They are aawesome though
Old 30th July 2009, 09:02 PM
A8, mate!
Guest
Posts: n/a
Cheers psyche! What should I be paying for one, brand new?
I'm new to all this...
Old 10th August 2009, 03:42 PM
Default Do Phatbox fit with all types of stereo/sat nav
I've got the Navigation Plus sat nav in a 2002 A8. Is that compatible?
I've seen list prices of close to £700, but I think Audi are off-loading them at closer to £150 at the moment
Old 10th August 2009, 03:56 PM
darrenjoe90's Avatar
i just asked tony this weekend about phatbox and he said he knows about somethig better and cheaper. just waiting for him to find out and let me know
Old 10th August 2009, 04:20 PM
Default Phatbox alternative
Cheaper than £150?
Old 10th August 2009, 07:31 PM
You can get the iPod adapter thingies for about the same price and they have similar functionality.
The PhatNoise works with all the head units up to RNS-E, though you may need to re-flash if it's used. It has voice prompts for playlists/albums/artists. Even the missus can use it!
Old 10th August 2009, 07:54 PM
thebluewhale's Avatar
This thread
http://forum.a8parts.co.uk/showthread.php?t=704
gives you the basics of what you'll need as long as you ignore the p1ssed off bits when nothing worked .
You can pick them up from about £80 second hand on Fleabay and they are a cracking bit of kit when its hacked.
I'd like to know what Tony has in mind as a substitute for it though.
Old 10th August 2009, 09:59 PM
CliveH's Avatar
CliveH CliveH is offline
I fitted one in the S4 and it really was plug & play, everything worked first time.
A bit dated now compared to the likes of MP3 players and ipods but essentially does the same thing. I like it
Paid about £160 for a new one from US ebay a couple of years ago.
They're not made anymore and there's no support for Vista for the software which you use to set up all the albums on the removeable hard drive, so make sure you have access to a PC with XP on if you're thinking about getting one.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 11th August 2009, 07:54 AM
Default Phatnoise better that a dension iPod adapter?
I've got a Dension iPod adapter fitted which plays Playlists on the stereo RNS 4.2) as if they were on of the 6 CDs from the autochanger.
But there is no information on the display, it just says, for example, "CD2, Track 34".
It's good in that you can have huge play lists, so you get more music than on 6 CDs, but it's track information on the screen that I'm interested in.
Any thoughts?
And is Tony on holiday????
