Old 16th February 2016, 06:55 AM
richardracer richardracer is offline
Default No heat in footwell
Hello everyone,
I have noticed that there is no heat in my foot wells on my 2006 D3 S8. The vents at the end of dash deliver heat and VCDS does not show any errors under hvac. Are there any common issues which I could check out. My seat warmers are getting a good work out!
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 17th February 2016, 02:52 PM
We are talking about the front footwells here ??
So the face vents , screen, end of dash vents are blowing hot and all good , this proves matrix is flowing and exchanging heat .
When the direction is at floor position is there air flow present but it is cold or no air flow at all .
If it is blowing but cold air it must be some kind of blend flap that is in the wrong position for when its in floor position .
Can you do the full hvac test with vcds that runs all blend motors and positioning flaps through there full working travel see if anything flags up then .
Old 17th February 2016, 05:50 PM
Default No heat in (front) footwells
Hi Mechnico,
Yes, it is front footwells suffering no heat. Setting it as manual and directing flow down with temp set to HI, still doesn't push heat to front footwells. Will try VCDS over weekend with full hvac test suite.
Thanks for your suggestions and love your photos of the inside of the v10
Richard
Old 17th February 2016, 06:10 PM
Not my v10 mate , just trying to help the op
