Old 27th February 2016, 01:56 AM
H-M3 H-M3 is offline
Default fuse 29 blowing
hi guys as per title the number 29 fuse which is 1am keeps blowing. i have changed it few times but same. i read about the armrest light causing this in most cases? i stripped the arm rest area and found that there is one wiring for left armrest and one blank connector. Can anyone shed light on this as I could not take the connector off!! is there a way of doing this to prevent blown fuse again?
kind regards
Old 28th February 2016, 06:32 PM
Disconnecting the illumination for the arm rest sorted the issue and cable will be investigated and new wiring run most likely done at the later date
Old 28th February 2016, 07:35 PM
Again big thanks to marcin as I was worried of just ripping the wire out. We unplugged the connection for arm rest light and Presto! Let there be light!! Thanks again marcin. Thnx for the lovely cuppa dude!
Old 28th February 2016, 07:51 PM
My pleasure mate , and as you know by now you are always welcome here
And we will sort this wire next time
Old 28th February 2016, 08:34 PM
Don't encourage to much mate might move in.
