Old 4th March 2016, 05:00 AM
TP_ TP_ is offline
Default How to remove headlights?
Hi.
Iīd like to have my both headlights refurbished and would need to have them removed from the car.
Iīve searched but havenīt found anything, someone knows how this is done?
//Thanks
Old 4th March 2016, 06:35 AM
Morning mate
Pull the front section of the arches out, 5-7 various screws and couple of pin clips
There are 3 size 10mm nuts on each side of the bumper starts from just below the headlight, all about 75mm apart from each other
Undo the engine tray on the bumper side, 3 big flat head twist bolts
Undo all 7x torx screws at the top of the bumper
Pull gently bumper off the car, first bottom corners where bumper meets side wings
On the right at the very bottom you will have two big connectors, pull the off the bumper for convenience and disconnect
To the left there is T piece for the headlight washers, unplug the hose
Done
Old 4th March 2016, 06:45 AM
TP_ TP_ is offline
Thank you, much appreciated
Old 4th March 2016, 07:01 AM
Completely forgot to mention
Two torx at the top of each headlight, two at the back (bottom) and two underneath accessible only when bumper is off
Old 4th March 2016, 11:50 AM
Page 127 of THIS DOCUMENT should sort you out!
