Old 4th April 2016, 02:25 PM
A8P's Avatar
A8P A8P is offline
Default gear box remap D3
Hi gents,
Anyone had any experiance with a gearbox remap? I was looking at doing this and combining it with a stage 2 remap. I find the gearbox just lags on changes and could be better.
How do i know which gearbox i have? Seems i need to know a DQ number.
Thanks in advance.
Audi A8 sport 3.0tdi Quattro, 19" wheels, 2tone leather, rear camera, heated seats, ami, Bose sound system, dab, xenon adaptive headlights, 4 zone climate control
Old 4th April 2016, 02:55 PM
Lee S Lee S is offline
MRC remapped mine slightly (changed something to deal with the extra torque) but said that it wasn't worth spending much time on IF all you want is quicker shifts... Something about it being a slow shifter. I think it's a bit of a lazy box but if anyone will know I guess it will be someone like MRC. Give them a bell. Won't cost anything to ask.
Mine is quite laggy in Sport mode as after the remap it just pulls like bu99ery all the way to the red line and when the TCU decides it needs to change gear, it's like someone has turned the engine off... Then the TCU makes its mind up to upchange a second later (which feels like 5 seconds when you're gunning it) and whoooaaaa..... off it gallops again toward the red line. I don't think you will ever get super speedy shifts from these older 6 speed boxes TBH.
Lee
2017 Nissan Leaf Tekna
Old 4th April 2016, 06:27 PM
A8P's Avatar
A8P A8P is offline
Thanks for the info! That's good to know. It seems to be the type of car/gearbox that loves to pull real hard and then you relax of the acceleration a little for a gear change and put your foot down again and away you go again with the surge of torque.
It's just frustrating that we can't get the box to be more snappy. Plenty of companies claiming to change gear change to be more reactive but as you say there probably ain't much we can do with it.
Check the link below.
http://www.amdtuning.com/audi/a8s8/d...ftware-upgrade
Old 4th April 2016, 06:40 PM
tgm147 tgm147 is offline
As far as I know neither the A8 or S8 have a DSG box but I stand to be corrected! I have done a remap on an A5 that had a DSG box though and it drove much differently than the old torque converter autos, which are just slow by design compared to a DSG box.
I find if I really want to push on, driving in manual is best. Change up at an indicated 36-3700 and by the time it's thought about it and actually done it, it'll be sat just under 4k so still pulling but not stopping on the limiter first.
Old 4th April 2016, 06:46 PM
Correct me if I'm wrong, but I don't think any variant of any D3 has ever been fitted with a "DSG" gearbox. They were either CVT or ZF 6 Speed Tip-Tronic. DSG is a "direct-shift gearbox" with the double gearbox/clutch system and I don't think there has ever been one fitted to a D3. So AMD Tuning... really? Generic incorrect ad on the website or complete lack of A8 knowledge?
As I said, speak to MRC as they are the boys to ask. The box in mine is the same box as an RS6 I think and the Q7 and MRC told me NEVER to expect anything much in the way of snappy shifts. It's just not going to happen due to design. They may be able to tweak it slightly but tbh is it worth it? I don't find it lacking any more and I tend to drive around in "Drive" and floor it and off it goes. I very rarely use Sport mode to be honest as with the extra torque of the remap, "D" mode works a treat coupled with a heavy hoof and kickdown.
Lee
Old 5th April 2016, 11:16 AM
A8P's Avatar
A8P A8P is offline
Ok well I think you have convinced me to leave it then. Just for future info if I purchase a 4.2tdi V8 quattro D4 is the gearbox different on that?
Old 5th April 2016, 01:01 PM
Yes. That's an 8 speed ZF and I wouldn't touch that either as it is a more modern unit but using the same technology as far as I know. Shifts may be a touch quicker on the new ones, but maybe someone who has had D3 and then D4 will be along to give you a more accurate view.
Lee
Old 5th April 2016, 01:27 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I've not driven a D4 or a car with the new ZF 8 speed 'box, but all the reviews of it suggest it's near faultless, in terms of efficiency, speed and the electronics knowing which gear to be in when you want it. It's used in tons of cars right now isn't it, like the go to auto 'box for all manufacturers.
2007 Mini Cooper S R56
Old 5th April 2016, 02:28 PM
I think if its a 3.0 tdi D4 then you will get the 7 speed s-tronic gearbox but for the 4.2tdi and S8 and W12 etc they stuck with the ZF 8 speed as it can handle more torque than the s-tronic box
Old 22nd April 2016, 05:51 AM
Artermis Artermis is offline
I don't know about anyone else but my auto box irritates me on occasions.
be interesting to hear your findings on the tcu map Lee, it bugs me that the box doesn't seem to use the torque of the V8 very well; like you want to give it a poke, rather than just riding the wave of torque you have to wait for it to decide it wants to downshift and it gets to a point where the revs are too far up there you're completely missing the torque band and your move ends up taking longer and feeling slower as a result.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
