Old 5th April 2016, 08:07 AM
ulfilias ulfilias is offline
Default Air supension overhaul
Hi there,
Have a few faults with the air suspension, so i've set about overhauling it!
First thing was the compressor!
This was helpful
http://forum.a8parts.co.uk/showpost....7&postcount=53
But mine is quite different (A8 PF 4.2 Sport). It's in roughly the same place, but it's rotated 90 degrees to this and in the lower section. I have a two pairs of 3 blue plastic air pods there. I found popping the fog light grill off and some judicious use of socket extension bars I could get it out without needing to part remove the bumper, though handy to have a second pair of hands ocasionally, particularly when putting it back together.
I used this
http://bagpipingandy.com/compressor.html
To refurb the compressor. It's £25 delivered and seems a good kit, though i've yet to fully test and my cyclinder did have a little scoring so I will have to see how it lasts.
Next to have a look at the Valve as I have an intermitent error on that (same wheel arch, other side)
Lee
Old 5th April 2016, 09:55 AM
Originally Posted by ulfilias View Post
Hi there,
This was helpful
I used this
Lee
I recently bought the Bagpiping Andy kit and had my compressor overhauled as a precautionary thing whilst the wheel arch liner was being replaced. Well worth doing if your mileage is over 100K
Old 6th April 2016, 12:31 PM
Hi There,
Mines done 130ish
It's all back together and so far no errors. In playing with vagcom and running the compressor up, it sounds a lot healthier and builds up preasure a lot lot quicker. I was able to go through the 4 wheel measuring alignment thingy and then also sort out the headlights which seemed somewhat reliant on the leveling.
I can select Lift when starting the car which I couldn't before. I also found that the compressor is purely electrical and can be run with the engine off. I did have a power line hooked up whilst testing so not to flatten the battery
Ta,
Lee
