Old 14th April 2016, 11:08 AM
Default Boot lid grommet is falling apart (offside)
Hello everyone,
Boot lid grommet is falling apart on the right hand side of the car.
This is where electric wiring harness is entering the boot at an angle.
Anybody knows how to fix it permanently?
I didn't find the original part number.
Maybe something from another car will work?
Old 14th April 2016, 11:12 AM
I think it's moulded on to the tube, so not separately available.
Mine did the same and I used a grommet/cap, I think for a mains wiring socket backbox, slit open to slide over and liberally smothered in black mastic.
Sort of works, but the design means that fitment is subject to a lot of movement as the boot is opened and closed so it won't ever last long.
Old 14th April 2016, 11:14 AM
Mine is not moulded onto the tube. Thanks for the suggestion Andrew.
I think on many D2s this grommet has disintegrated, so there must be someone who repaired it permanently. Any more solutions?
Old 14th April 2016, 02:40 PM
Looks very similar to the B5 A4. I'll have a closer look this evening
Old 14th April 2016, 03:40 PM
The geometry of the whole setup is wrong, try watching how it all moves as you open and close the boot.
Once I removed all the old grommet (it was sort of glued on, not moulded) I pulled the pipe out of the lid a bit to introduce some slack and slightly rerouted it as shown, before fixing the grommet and gunge.
This way it twists that section of pipe with less leverage at the grommet:
Old 15th April 2016, 10:13 AM
Sugru from maplin
Shirish: 2001 S8
