Hi all.
I have the air sports suspension. None of the settings make a damn bit of difference to the ride quality. Comfort or dynamic are exactly the same, rock solid. Lift raises the car as it should, but ride comfort never changes? Any ideas/resets or something I can do? Is there really that much difference between the settings? |
![]() Quote:
Have a look at This thread first - may give you an idea. in theory it should reset when you start it, but if you've got problems with either a leak in the system somewhere or insufficient pressure from the pump then it will normally show the orange fault light or be regularly showing the green light to show you are below ride height as the pump struggles top keep the accumulator tank full and maintain pressure in the system, in which case you may need to replace compressor pump. Couple of useful threads if so - Modified VCDS Label File for Air Suspension - helps you to test your system using vagcom, the compressor should be putting out up to 16 Bar Changing the Compressor Good luck! ![]()
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 31st May 2016 at 07:58 AM. |
Thanks very much, I've had the compressor out and replaced the piston ring and it's vibration dampers already just as a matter of passing the 100k miles mark I thought it should be done, I'm sure that's fine.
I don't drop any height if left and no warning lights. I might try removing the battery for 24 hours then go for a drive in dynamic and see if it relearns. Thanks again. |
