Old 1st June 2016, 06:32 PM
davidamd davidamd is offline
Default front pad brand choice
the a8 is a bit squeeky on stopping i think due to cheap pads.
front disks are new rears need changing
i have the 8 pad lucas set up on the 4.2 and looking on eure for standard pads as fast road are well onto the hundreds of pounds
so the choice is between pagid although as its euro and own the name they are not what they used to be or brembo,
is there anything between them
Old 1st June 2016, 08:00 PM
Given those choices, Brembo for preference.
Old 1st June 2016, 08:03 PM
Go for Brembo. I had Pagid once and they cracked causing a number of issues. See my thread which I'll try and get the link to.
Old 1st June 2016, 08:05 PM
See here:
http://forum.a8parts.co.uk/showthrea...ighlight=PAGID
I always go for brembo pads and discs front and rear. Never had a problem.
Except for rear calipers sticking, but that's a caliper issue.
Old 2nd June 2016, 06:18 AM
There are 2 different brakes on PF D2 A8, 314 and 323mm front brakes. Audi part numbers are different for front pads for different sizes, I think they can be interchanged but not 100% sure. The difference is that 314mm pads comes with counter weight to reduce nose, vibration and 323mm without, probably because they would get too close to wheel with the weights.
I have 323mm brakes and I had some very hard unknown make pads for about £20(OEM are over £150) and they would squeak a lot. On the plus side they did not waer at all and there was no brake dust on wheels. In about 13-15k miles there was barely any wear at all, disks was probably more worn than pads.
Last year I changed to Apec pads and have been very happy with them, decent stopping power, does not squeak, does not brake down at high temperatures when braking hard and a lot but theres is a fair amount of brake dust on wheels but not as much as from OEM pads. Got them for about £8 from e-bay. That reminds me that my intention was to buy couple more sets if I liked them. Off to ebay now see if I can find them again.
Edit:
Found them http://www.ebay.co.uk/itm/BRAKE-PADS...item20e1dfba93
5 sets left, I think I will buy another 2, that should sort me out for another 10 years.
Old 2nd June 2016, 06:42 AM
The pads do interchange Ainars i swapped my 314's to 323 the pads are the same but the calipers are different, but look the same.
Old 2nd June 2016, 04:25 PM
mine do have the counter weights as i can see them but i have acess to vrm part no search so can get the gen number off the reg,
apec are a good standard pad i used to sell them many moons ago but looks like the brems will be the way to go
pagid are made at tmd friction now so same factory as delphi and drivetec etc
Old 2nd June 2016, 06:15 PM
looks like mine are pad 940 in apec and a quater of the price of brems,but brembos though lol
Old 3rd June 2016, 03:24 PM
And received 2 sets today all for £23.50 delivered.
