Old 9th June 2016, 12:20 PM
Takemetothepub Takemetothepub is offline
Default Digital Speedo
Anyone know if there is an option to have the speed as a digital value on the instrument cluster like in other Audi models?
2005 6.0 W12 Quattro SWB - Need an OPEC membership to run it!
Old 9th June 2016, 12:21 PM
Yes there is, but it's for non-ACC D3's with the wide screen cluster.
Matt
Old 9th June 2016, 12:47 PM
I'm fairly sure it came into most Audi models around 2007, the A8/S8 included.
My TT / Q7 has it, so did my RS6, and my D3 S8.
Old 9th June 2016, 01:23 PM
Conquistador's Avatar
Mine has wide cluster (which comes with ACC) and the digital speedo can be selected by cycling through using the button on the underside of the wiper stalk but that's a 57 facelift car so...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 9th June 2016, 01:43 PM
Yes, just re-reading Marcins Widescreen retrofit guide and the pattern is the digital speedo was available on PF and 1st FL D3's without ACC. Model Years 08+ (like yours) it was probably available on all widescreen clusters regardless of ACC.
Matt
Old 9th June 2016, 08:08 PM
Guy swapped my 2004 3.0TDI display for a newer wide screen display. Now I do have a digital speedo, amongst other things that I wanted.
I suppose this means that it is instrument cluster dependant rather than car.
Old 10th June 2016, 08:55 AM
Thanks chaps, looks like my 2005 with just have to go without
