Old 13th June 2016, 02:52 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Undertray clips.
Hi all. I need about 10 undertray clips (interesting afternoon's driving). I've heard they're £5+ each from Audi. Is there anywhere I can get them cheaper? I don't have a TPS account, and don't mind ordering off eBay, but want to make sure I get the correct size clips before ordering.
Help!
2007 Mini Cooper S R56
Old 13th June 2016, 03:04 PM
I think these are the ones you need for D3 http://www.ebay.co.uk/itm/10xSet-Aud...-/181752758720 but there should be retaining washers in the set as well.
Old 13th June 2016, 03:26 PM
Johnmed's Avatar
Thanks very much. That's the buggers. They're exactly like the one I have in my hand! Just ordered some from a UK seller using the part number. I owe you one
Old 17th June 2016, 03:56 PM
Johnmed's Avatar
Thanks again to ainarssems. My screws arrived and I fitted about 7 of them today. A few of the retaining clips had corroded and I used nuts and bolts in their place, given that I use an oil vacuum to change the oil it's no concern. The undertray is going nowhere!
My advice to others would be get more than you need, also buy the retaining clips too.
All the best.
John.
Old 7th July 2017, 12:40 AM
H-M3 H-M3 is offline
Default bump
need to order some, how are your clips surviving?
cheers
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 7th July 2017, 06:50 AM
Johnmed's Avatar
The screws are fine, but my retaining clips were past their best. I used nuts and bolts more than the clips. I use an oil pump so don't need access to the sump regularly.
In retrospect I would order clips and screws.
Old 7th July 2017, 08:05 AM
Thanks. Would you recommend the Fleabay ones?
Old 7th July 2017, 08:43 AM
Johnmed's Avatar
The screws I got were perfect. I'd just advise you renew your clips, as they rust away.
Old 7th July 2017, 03:49 PM
Turbo Tony's Avatar
I hate those things - they keep working their way loose on mine.
Storytellers Villa Orlando
2008 Audi S8
Old 7th July 2017, 04:05 PM
Johnmed's Avatar
They are hateful things. I've seen the undertray hanging low enough times to just bolt the thing in.
