Old 23rd July 2016, 06:54 AM
Dxthomas Dxthomas is offline
Default Centre Prop & Oil Seal
Not exactly the news I was hoping for...
Car has been in for a full service, and they have found:
1) Centre Prop bearing is worn - causing an annoying whirring noise in the cabin
2) Suspected oil leak from the rear engine seal - engine out job to fix
Damm!
Present
2017 Golf R Estate
2007 Volvo XC90 D5 SE Sport
Past
2006 D3 Audi A8 4.2 tdi LWB
Solar Sunroof, auxiliary heater, DAB, TV, ventilated front seats, heated front & rear seats, AMI, ACC, power boot close
Location - Exeter, Devon
Old 30th July 2016, 06:33 AM
Turbo Tony's Avatar
Ouch. As someone also facing a big bill for repairs, I feel your pain and wish you the best of luck fixing it.
Storytellers Villa Orlando
2008 Audi S8
Old 30th July 2016, 07:02 AM
47p2's Avatar
47p2 47p2 is offline
What's caused the rear oil seal to fail?
Usually caused by either wear (high mileage) or overfilling the sump with too much oil which puts a lot of extra pressure on the seal causing it to fail
Nite Blue 3.0L SE Quattro
Old 30th July 2016, 08:12 AM
Code:
Mine seems to be doing this. How did you diagnose?
I can't tell where the noise is coming from as when I turn my head.
It sounds like some metal being gently turned on a lathe or almost like a hosepipe running but not as loud.
I will try jacking up and spinning the wheels today and hope it is not a prop bearing.
