Old 19th September 2016, 04:59 AM
Artermis Artermis is offline
Default Changing Bottom Arms - Any Advice?
Morning all,
The front end of the '8 is starting to knock over uneven surfaces, had a play with a pry bar and the front end, lower rear arm seems rather slack, so I think the bottom arms need replacing. I have paperwork to suggest the upper arms were replaced earlier in the year prior to my ownership so it's them or ARB.
Are the bottom arms a job I should be attempting and can achieve on the driveway? Am I going to run into pinch bolt issues or anything like that? Any advice appreciated!
Thank you,
Ben
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 19th September 2016, 05:27 PM
Joe2.0E Joe2.0E is offline
I'd suggest removing the ARB as it's quick and easy and go for a test drive without it. If the noise is gone, you've found the culprit.
If it is the ARB, you have to buy it complete as bushings are not available.
Old 20th September 2016, 12:16 PM
I'd agree with that - replaced mine recently and it cured mine of small knocking noises that seemed to only come when the engine was cold or over slight bumps. If I remember correctly the whole ARB was about £130
Old 22nd September 2016, 03:22 AM
Disconnected the arb from drop links / c links last night will give it a test on way to work this morning and see what happens.
The noise did seem most apparent over uneven surfaces, which is when you'd expect there to be loading across the ARB so it is possible that is the culprit.
The bushes do still feel very tight on it though and don't look all that unhealthy either, so it could be a real bonus and just worn links.
Will soon find out.
