Old 26th October 2016, 04:40 PM
oldnick oldnick is offline
Default FL windscreen washer problem
coming up to MOT time and no doubt it will fail if both sides don't work ....
drivers side ok , but just a few bubbles on the passenger side so tried to unblock with an ultra fine needle....no change
so unclipped the end and noticed the twin wires connected to it so pulled off the plastic tube and operated the washer switch ......drivers side as before and strong gush of liquid out of the open passenger side tube
well, I already knew the pump worked , question is what are the electric wires for ? only thing I can think of is that there is a switch in the end fitting to stop the liquid from running back
so maybe a new fitting on the end ? any suggestions ? any part numbers?
Old 26th October 2016, 04:44 PM
Wires will be for heating elements in the nozzles.
Sounds like the passenger nozzle is still blocked... More needlework required
Old 27th October 2016, 08:54 AM
tks ian , all fixed , unfortunately needlework wouldn't do it because what was blocking the jets was a gel like consistency and the needle just stirred it
however went next door , detached the end , put a fine jet fitting on the airline and 8 bar pressure gradually cleared it by blowing to and fro, even then had to use the washers to clear the last bit out
now to get the headlamp washers working , probably just the filter , not needed for the MOT as I understand it so can wait
Old 27th October 2016, 10:03 AM
Result
Old 28th October 2016, 09:12 AM
The "snot" like substance is bacterial build up and it is possible that it contains Legionella bacteria so just be careful when blowing it about with an air-line! It will grow in the spray heads particularly because they are heated and bacteria just LOVE the warm conditions which is why they grow in cooling towers and air con units.
