Thread Tools
Display Modes
When you engage contact everything lights up and says OK only abs light and triangle for esp.those 2 wont light at all.
So i accessed the unit with vag and ut gives 2 codes. One 00301 abs return pump (which i will repair next weekend) and 001486 which can be sorted after the first error is removed. But i am confused Why no beeps or abs and esp errors on start or while driving??? Definately no abs or esp works(tires slip on start and no abs when braking) Also when i press the esp disable button in the dash nothing happenes. So any ideas? Photos of the errors in atach Maybee some coding issue??? https://postimg.org/image/4em7hzgvz/ https://postimg.org/image/x4wkigusz/ Can someone please check how this looks in his car?? Mine is d2 2001 2.5 tdi 132kw facelift 6speed manual transmision withouth quattro and with esp Last edited by milenajdoski; 13th November 2016 at 03:51 PM. |
