S8 D3 coilovers?
Just thinking out loud here...
Newbie so don't shoot Can the OEM suspension be removed and converted to coilover suspension? Mine has a leak, and the previous owner has tried a number different fixes, new struts, new compressor, still slow leak on the front... I'm thinking if I have no joy, what are my options??
Instagram : n__i__l__s |
I have never looked into it personally, but how about the distribution valve in the passenger wheel arch near the A pillar??
Damaged air line?? If it's a driver side front then air line for it runs along the steering rack on the back/bottom ish of the engine bay Have you got any proof of the actual strut and compressor being replaced to try and rectify the problem ??
The short answer is yes, it can be done. I've heard of it and seen it done, on another forum a while ago I think it was. I'd imagine it won't be cheap (I'm thinking Bilstein or Eibach). If you want it done properly I'd consult AMD in Essex personally. Good guys and they know what they are doing when it comes to custom set ups.
The few threads I have seen about this being done ends up being a pain in regards to the car complaining that the level control system is malfunctioning. And they were never able to code it or do otherwise to fix it. Also things like headlight level control is tied to it. So worth keeping mind if your going to down that route.
Del |
I have seen it on American forums with photos but not something I would consider so didn't note the details but it is out there somewhere.
EDIT* Are you using Bing? http://pbbrakes.com/audi-a8-d3-coilo...nsion-kit.html http://www.strutmasters.com/products...onversion-kit/ |
Can you see that it has new front struts as these are fortunes of the dealer ....perhaps second hand ones ??
Use the lift function and put the car to full height ....then activate jacking mode to lock the settings in ......do not lock the car up as it may knock it out of that mode . See if the car drops now , what this does is move the rolled edge of the air bag to another area away from the place where they crack and become pourous . If it does not drop that rules the pipe work out from leg to corner valve .....if the pipe work is chaffed it will still drop . We do alot of land rovers with air legs .....on them i put them to full height and remove battery lead as even dormant the car can still intevene and lower the other legs to the leaking legs height to keep the car equal and balanced .........thats why one leg leaking can have the affect of dropping the whole car on its arse ......then the compressor has to works its arse off to get the car back to ride height thus over working the compressor till it gives up . |
Under the aluminium cover on the air legs it like this
When you go to full height the strut sits on a 'new ' area so the cracking is not as exposed . Gone off on a tangent here as your on about coil overs ....I wouldn't want to take the air suspension off ...when it's good you cannot beat it ....self levelling and the ride quality and so on |
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Glacier White |
