D3 - Everything Else Anything that doesnt fit elsewhere |
Thread Tools
Display Modes
Done
Off side Turbo, actuator, & oil seal replaced Fuel flap actuator Upper and lower front suspension arms x 8 Repaired CV outer boot Battery replaced & coded Boot soft close motor replaced Drivers door card replaced Removed dark tint 4 x alloys refurbished 4 x tyres replaced Wheel alignment checked Front & rear pads replaced EPB repaired/ replaced (both sides, complete with new calliper seals) Suspension level sensor replaced front near side MMI (sticking button) removed & cleaned (coke liquid!) Interior LED lights fitted LED side light bulbs replaced with error free bulbs. Full service (air/ fuel and oil filters, 9l oil) Front wheel bearing replaced Front passenger seat lower motor jammed (released) Horns replaced Near side bonnet catch repaired Drivers side intercool pipe split - repaired Brake discs (lip removed), callipers, dust plate painted heat resistance paint New alloy wheel centres 2 x number plates Front near side wing rear foam seal Inlet manifold removed and cleaned x 2 Brake switch repaired Replaced rear centre arm rest Injectors x8 cleaner added VCDS professional software and lead Water channel cleaner - anti freeze/ coolant added. To Do Paint rear pass quarter, front and rear bumper, and drivers door Decrome some exterior trim Replace auto dip/ heated drivers mirror glass Fit boot lip spoiler (low profile) Replace rear lights LED spec x 4 Power chip +70bhp - 340bhp Fit removal tow bar and electrics Repair drivers seat boaster leather damage/ upgrade full leather Fit OEM mud flaps x 4 Fit OEM mats x 4 Fit engine under tray Replace inner front guards x 2 Fit rear near side jack point Fit 10mm wheel spacers complete with extended bolts x 20 (alloys ET40) Buy OEM Jack Fit custom suspension level link arms x 4 Order spare key Fit OEM MMI iPhone interface Upgrade MMI Fit Rear OEM ICE (Headrests) Fit OEM wheels / winter tyres R18 Replace front grills with homemade custom honeycomb x 4 Fit homemade front wing air vents (design TBC) Replace front pass seat rely module K&N Air Filters x 2 Stainless Steel Exhaust OEM roof bars Replace bonnet release cable Brake fluid change AC seals replaced and re-gas. Rear window replace (heating element defective) OEM manual Workshop manual Interior button repair paint Shark fin roof S8 Door mirror covers Auto retract door mirrors module on key lock 9 x faults heater related, motor flaps etc!
2003, A8 D3 4.0 TDI |
That's quite the list.
Look forward to updates as you go
Del ![]() |
