D3 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
Hi
This may seem like a daft question, but what is the headlamp bulb number for the dipped beam, most common is H7/H4 but aren't these lights bi- xenon. My lights have the cornering feature not sure if helps at all. The N/S has a light blue colour which I don't like, the O/S has a new headlamp not sure about the bulbs as garage fitted this. I hope that I've given someone the info that could tell me. I could of course take the bulb out, but its cold and I have a very long list of jobs on this car before I can go spending money on such luxuries. Thanks David |
I believe if they are Xenon then you need D2S
Check here, it's fairly accurate http://www.autobulbsdirect.co.uk/ |
Thanks for the link
Just looked and there's loads to choose from. Which do most people use. Thanks |
I bought these...
http://www.autobulbsdirect.co.uk/D2S...-HID-Bulb.html They work fine, but not worth the extra money as I can't really see any difference in brightness or whiteness over stock, I hoped they would be as white and bright as new cars with HIDs. I got them from Amazon (amazon themselves not a marketplace seller) https://www.amazon.co.uk/XENARC-INTE...=66240CBI&th=1 |
Thanks for your help.
Will keep these in mind when I get through some of the other work. Front suspension first job. update mmi buy vcds cable as well. N/S rear door not working keyless everything else works. replace led strips on the n/s. Then work on the faults. |
