Old 28th December 2016, 05:34 PM
clubadria clubadria is offline
Default AMI retro-fit
Can anyone say will a used one work with the right cables from Audi, or is there more to it than that.
Seen a used one for £100 without cables.
This is something I would like when everything else is fixed.
Old 28th December 2016, 05:46 PM
£100 is quite cheap for a 2G MOST AMI - There are loads of canbus ones, that looks virtually identical, but don't have fibre connections on them from the A4/A5 etc. and are usually a lot nearer £100.
A 2G one second hand will usually set you back around £200.
Cabling isn't difficult, but you may need an MMI firmware update to make it work if you have an older version at present.
Old 29th December 2016, 05:58 PM
That's why its £100 then as I think its from a A5.
I had read somewhere about most, but couldn't remember why.
The lady at A8parts did say they are rare in my age car.
So will have to keep looking.
David
