Old 10th January 2017, 08:07 PM
Simonbartlett Simonbartlett is offline
Default Possible parking brake noise
Tonight I parked my car on the drive put in park, didn't engage parking brake, got out and locked. A few seconds after locking something sounded like the hand brake cycling a couple of times. Is this normal or an electrical problem, I'm hoping its the car doing a check of some sort. Thanks
Owner of a 2008 A8 3.0tdi SE
Old 10th January 2017, 08:22 PM
Lee S Lee S is offline
Normal. If you select park and engage the steering lock it does a built in calibration where it winds out and then in. Nothing to worry about and should maybe be done once in a while anyway to re adjust and exercise the motors and screws etc.
Lee
2017 Nissan Leaf Tekna
Old 10th January 2017, 08:30 PM
Great news thanks one less thing to worry about
Old 10th January 2017, 08:32 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Completely normal and in my opinion quite bleeding annoying. When you arrive somewhere relatively quietly, park up and walk away, Mr Audi decides the whole occasion has been just that bit too quiet.
Next thing:
whirrrrrrr,.. whirrrrrrrrrrrr,.... ..... whirrrrrrrr,.. whirrrrrrrrrrrrrr.
Classy!
2007 Mini Cooper S R56
Old 10th January 2017, 09:28 PM
Why are you parking up and walking away without putting your handbrake on?
Lee
Old 10th January 2017, 09:29 PM
Johnmed's Avatar
Cos it's in P!
Old 10th January 2017, 10:29 PM
You should firstly use the EPB to secure the car no matter what the terrain is and then select the "Park" mode on the gearbox as extra security. Only using "Park" mode can cause wear to the locking pawl in your transmission (which, if it then shears, means your car will roll away) and, as you have noticed, cause frequent and unnecessary EPB calibrations, wearing out your EPB motors. Your hand has to pass over the EPB button twice when you stop, so what's the hardship in pulling the button up before you select "Park"? Better safe than sorry in my opinion but that's just me.... It's your car at the end of the day.
Lee
Old 10th January 2017, 10:44 PM
Johnmed's Avatar
I take your point Lee. I use the EPB when at traffic lights etc and when parked not on level ground. However I'd always considered a pawl brake to be more than adequate on level ground.
Maybe I'll use it a bit more in future
Old 11th January 2017, 05:22 AM
I know you should and if not on level ground I always use the epb but my drive is perfectly level. I have always done this with Automatics and haven't broken a gearbox yet. I believe in America where nearly everyone drives an auto they actually call the hand brake an emergency brake and they hardly ever get used.
Old 11th January 2017, 07:43 AM
Joe2.0E Joe2.0E is offline
In the 5 years, I had a 2004 D3, I stopped using it unless I really needed to as it was the most unreliable set of components in the car. I had to replace the parking brake motors on both sides, the ecu and the switch in various stages over the first 3 years I had it.
One particular morning, the left hand motor had packed up in the on position on my driveway, much swearing and an hour later, I was mobile again.(There is a tool in the toolkit to manually unwind the caliper.)
Hence my reason for not using it.
The parts were revised a few times over the years and it may be more dependable on the later D3's but theres a lot to be said for a ratchet lever and a pair of steel cables.
