Old 16th January 2017, 09:01 AM
Teffers Teffers is offline
Default Central locking - autolock on departure?
Greetings.
Tried searching - apologies if this has been covered before.
Can the central locking be coded to lock as the vehicle starts moving?
2001 D2 S8. I have VCDS VagCom.
Thanks for looking!
Old 16th January 2017, 09:27 AM
Yes, at about 15mph IIRC, did it on mine, simple bit of code change using VCDS.
1 Rear boot unlock & opened (only some models e.g A4)
2 Flash indicators on activation of alarm
4 Security central opening (drivers door only opens not passenger) with key
8 Anti-theft alarm switched on
16 Cabriolet functionality on (reverse pump direction)
32 Auto lock doors when car goes above 15mph
64 Comfort opening/closing of windows
128 No ultrasonic installed (cabriolet has no ultrasonics)
256 Unknown (rear boot logic with remote A4 ?)
512 Radio control close confirmed with one flash
1024 Anti theft alarm set confirmed by horn beep
2048 US window logic (Power windows do not work once door opened)
4096 Radio control open confirmed with two flashes
8192 Radio remote control opening/closing activated
16384 No Security central opening (drivers door opening only) with remote
Old 16th January 2017, 02:19 PM
Mega - thanks!
I'll have a look later
Old 16th January 2017, 02:24 PM
Check (and record) what coding you have, it will be the sum of the relevant selection of the above, and adjust accordingly.
Chances are you just need to add 32. But you may want to make other changes.
Old 18th January 2017, 03:52 AM
Worked a treat - thanks.
I can't figure out what else I'd want to change at the moment though!
Thanks for the advice
Old 18th January 2017, 09:17 AM
This document is useful.
Old 21st January 2017, 12:12 AM
RS6's Avatar
RS6 RS6 is offline
get it to cherp when you lock it i do this to every car i get hold of
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
