I picked up a battery drain issue over Christmas which I managed to locate to a 20amp fuse in boot using my multimeter.
I've been disconnecting this for the past few weeks and no more flat battery. This is the fuse which The stereo runs off. Do you know if anything else is in this circuit relies on this fuse? If it's only the stereo then I will go back to the audio shop. If there are other appliances running off this do you know where I can get a wiring diagram from? Cheers Rich
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ![]() 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Glacier White |
