Old 13th October 2009, 11:57 AM
Zip's Avatar
Zip Zip is offline
Question Battery replacement
My battery has been relatively weak since I purchased the car. In fact, a service in 2007 (before I took ownership) hilighted that it needed replacement. The cold weather over the last few days, and a lot of short journeys, has finally killed it.
Anyway, looks like it was the original battery - lasted 7 years, which can't be bad.
Noticed the original (VARTA) was rated at 92AH, which is relatively high. I have replaced with a BOSCH 100AH battery. Does anyone know what the recommended spec is?
NB: a pain to replace...need to take the lid off the fuse cover to get it in at the right angle under the almost imovable positive lead...not much skin left on the knuckles.
New battery has made a hell of difference to the car.
PS: I have never seen the little venting tube from the battery on a car before. I assume this is needed because the battery is mounted in the sealed boot rather than under the airy bonnet?? Any ideas?
Zip
2002 S8
Old 5th November 2009, 09:58 AM
Zip's Avatar
Zip Zip is offline
Question Ditto...
Zip
2002 S8
Anyone know what the official battery spec is? All the websites show slightly different stuff.
Zip
Old 5th November 2009, 08:24 PM
I have an original Audi battery of 95Ah.
Old 6th November 2009, 06:43 AM
Oli18's Avatar
Oli18 Oli18 is offline
Hi Zip,
I have a spare one which you're more than welcome to have for free - it's in good nick and has about 2 years warranty left. I have the receipt too should it fail.
Oli
Audi A8/S8 D2 Flickr Group
Old 8th November 2009, 03:59 PM
thebluewhale's Avatar
I've just checked the options codes on my car. The original battery is 450A (92 AH) if this helps anyone out.
Old 15th November 2009, 01:26 PM
AndrewGray AndrewGray is offline
Replaced mine with one from Audi:
part number 000 915 105 AH
12v 95Ah 450A DIN
760A EN/SAE
