Old 18th April 2017, 09:47 AM
JoA8D2 JoA8D2 is offline
Default Mirror Folding problems
Anything I'm missing on these useless mirrors of mine?
They have never folded properly with the N/S now not working at all, the O/S folds intermittently on it's own but never on the switch.
I have read the other threads on the forum and have replaced both the drivers door switch panel (no change) and now the control relay (bottom of O/S B pillar).
I have stripped the N/S mirror housing and the motor for the fold doesn't seem to have any power to it (when activating switch), althoughI have tried putting power to it but this still doesn't fire it into life !
Could be the motor is toast? I am wondering if there is another relay for the motors (separate to the O/S B pillar one).
Any help or things I may have missed would be welcome
1999 A8 D2 2.8, owned since 2012, stopped the leaks, don't mind the MPG, originally AUDI UK car.
Old 18th April 2017, 10:15 PM
Ages ago I had mirror folding problems on my old PF S8 (grey on in my sig pic). Bought a spare from our sponsors.
Then I took the failing one off and investigated it, eventually making it work fine.
The solution in my case was lubrication; lots of WD40 introduced from the underside with it sitting upside down so that it penetrated the gears.
I rigged up a power supply (old spare modem PSU IIRC), having (can't recall how) worked out which leads needed 12v to make it fold or open. I then exercised and lubricated it until it worked perfectly.
Old 18th April 2017, 10:16 PM
Maxis Maxis is offline
Default Control relay
Yes, yes there is. Theres a folding mirror control relay is in the relay panel below the passager footwell carpet. Its a large relay/ control unit, about the size of two relays put together. The unit in the os b pillar is for memory fuction only.....
Audi A8 2.8 Quattro sport 2002 light silver met. with final edition 20s....
Old 18th April 2017, 10:48 PM
See here: http://forum.a8parts.co.uk/showthread.php?t=5047
Old 19th April 2017, 04:09 PM
HP, thanks for that, yes I read your thread, and used the instructions to strip the N/S mirror, I will probably oil them if I find the relay is getting them going again as they are in the weather a bit aren't they !
Old 19th April 2017, 04:10 PM
Maxis, star…..thanks m8, I will spend the necessary to buy from A8 and then see if they work any better !
Old 20th April 2017, 07:47 PM
Does anybody know what the relay part number is for the mirror relay in the passenger footwell?
Old 20th April 2017, 08:48 PM
Based on your spec of car, I think this is what you're looking for. There are two really, one for each side, J351.
Old 21st April 2017, 06:37 PM
Steamship, thanks a million, thats what I need to identify them I hope, I'll post the result.
