Old 23rd June 2017, 11:43 PM
Default Super VAG K+CAN fault code reader, key coding, PIN reader
I bought it to get PIN code to code additional keys and transponders for remote start on my D2 S8 and C5 A6 which I have done successfully and since I have PIN's now I have no more use for it now. It does offer pretty much all of the diagnostics that VCDS would and also single function key coding but for me if I just did key coding straight from it engine would work with the key but immo lkght were flashing and it was showing error code 'key incorrectly coded' so I just used code I got from it with VCDS and it worked just fine. I bought it as it was a cheapest way to code key on my S8, there are cheaper tools that will do D2 1994 -1996 with white immo box but very few for black immo box 1997-1998. It will not work on petrol FL D2's but should work on early D3's from what I understand but never tried myself.
Here is an example with details; http://www.ebay.co.uk/itm/Super-VAG-...0AAOSwiOFZOj-1
I paid £80 couple of years ago, the price has gone down since and I will be happy with £40 +postage costs
I am no expert but if you have any questions please ask and will do my best to answer.
Old 24th June 2017, 12:18 PM
What year A6 did you use it on please? I never managed to find a tool which would work with my 01 which was Immo3.
Old 24th June 2017, 02:07 PM
It's model year 2001 although it was made in the end of 2000. Immobiliser is built in the instrument cluster and I believe it is Immo3, up to 2000 it had separate box with immo2.
Old 24th June 2017, 03:15 PM
Worth a punt then I'll take it please
Old 24th June 2017, 03:32 PM
PM sent.
Old 1st July 2017, 08:37 PM
Sold now and received by by buyer, hopefully it will be all Mikki expected.
