Old 12th July 2017, 10:03 PM
NOR_KNet NOR_KNet is offline
Default Relay overview
Hi!
Im going on a long trip on saturday and need to figure out whats wrong with my oil sensor.
Ive replaced the oil sensor in the pan but still get an error code with signal to high.
Some had mentioned that it could be the relay that needs to be replaced.
So, does anyone have an detailed overview about what relays that is located underneath the ECU?? Or if anyone know where the relay for the oil level sensor is located?
Regards
Kenneth
Old 13th July 2017, 12:10 PM
Case closed.
Figured out that my after my dealer had replaced the AC Compressor this winter that the mechanic had forgotten to connect the Oil Temperatur Sender (G8) thats located in the front of the car, below the AC Compressor itself.
"clicked" the plug back in, deleted codes and everything is back to the way its supposed to be d
Old 14th July 2017, 09:29 PM
Glad you got it sorted
its really easy to miss connecting up sensors on these cars - far too many!!
