Old 13th October 2017, 01:30 PM
Paulg390's Avatar
Paulg390 Paulg390 is offline
Default Injectors wanted for D2 4.2
Sadly my 1998 S8 has developed an intermittent misfire after standing when warm (heat soak related). It looks as though it is an injector as had them all tested and 2 had impedance slightly out of tolerance. Once put back in only one now seems to be giving an issue and the fault code chases that injector if It get moved from cylinder to cylinder. So I am looking to try and replace one or preferably both the injectors but A8 parts don't have any in stock. Don't suppose anyone on here as some spares laying about... ?
The part number is 077133551 L , apparently the L is important.
1998 S8 Prefacelift
Old 13th October 2017, 04:07 PM
Good luck finding second hand, I could not find any. All I found for sale was complete set with the rail and when contacted seller they were already gone. Ended up buying new from Audi for about £150. On the FL S8 they are a lot cheaper.
