Old 13th January 2018, 01:49 PM
Kingsman Kingsman is offline
Default Airbag Light - Can't find Blue/White wires
Hey everyone,
I've recently purchased an Audi A8 D2 4.2 V8 and I absolutely love this car! The one thing annoying me the most currently is the notorious Airbag light. I've looked at other threads in this forum and decided to go the resistor route, so I ordered the 470 Ohm resistor and tried to fit it today.
Moved the passenger seat to make some working space, disconnected the battery and started looking for the Blue/White wire plug but I couldn't find it
I've attached a picture below, would love some help in trying to figure it out.
Old 13th January 2018, 02:11 PM
Welcome, pictures (of your car) are a must! Does it have sports (Recaro) seats with the moveable thigh support?
Old 13th January 2018, 02:42 PM
Pictures coming as soon as I find the right place and time for a photoshoot! They should be the comfort seats, is there a difference in the wiring?
Old 13th January 2018, 02:43 PM
I believe so.
Old 13th January 2018, 02:55 PM
I believe so.
Alright, any idea where I should put the resistor?
Old 13th January 2018, 03:00 PM
Me, no as I've only ever had sports seats which almost inevitably fail in the thigh pad; but have you had a VCDS scan to confirm where the problem is?
Old 13th January 2018, 03:15 PM
Since both seats are made by Recaro, I'd guess the exact same sensors are used in both.
Unfortunately I don't have any equipment yet for scanning but I do plan on buying OBDeleven sometime soon.
Old 13th January 2018, 03:36 PM
Not necessarily, do yours have a moveable thigh pad?
If so, slide it forward, tilt the seat back and look underneath; the wires to the sensor in it should be obvious.
Old 13th January 2018, 07:32 PM
The comfort seats don't have the movable thigh pad or the troublesome sensor. You'll need to scan it to see what the code is.
Where are you? There may be a member nearby who can scan it for you
Old 13th January 2018, 09:58 PM
Guess I'm going to have to live with the Airbag light for a little longer then
Having someone help with scanning for codes would be perfect but unfortunately I live in Estonia
