Old 1st February 2018, 09:48 PM
neeldub neeldub is offline
Default How to clear error codes in 5F Information Electronics Unit
Hey guys, a few years ago i updated the navigation maps on my MMI 3G headunit which i had obtained from ebay with an acivation SD card. After having successfully performed this procedure i have been stuck with permanent error codes noted below until now.
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 666 K HW: 4E0 035 666 B
Component: H-BN-EU H41 0187
Revision: -------- Serial number: 454F4097509977
Coding: 010101000000D3FF70000715FF7F00030001
Shop #: WSC 00029 210 86049
VCID: 2E54842B796DB53633-807A
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Subsystem 2 - Part No SW: 4E0 919 604 A HW: 4E0 919 604 A
Component: DU7 High Alu H43 0306
Serial number: 9357IQ091003158
Subsystem 3 - Part No SW: 4E0 910 611 HW: 4E2 919 612 K
Component: E0380 Bedient H01 0050
Serial number: 00000000085170
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
3 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 151661 km
Time Indication: 0
Date: 2017.12.26
Time: 23:21:03
Freeze Frame:
Voltage: 13.30 V
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 151661 km
Time Indication: 0
Date: 2017.12.26
Time: 23:21:00
Freeze Frame:
Voltage: 13.40 V
After having done some research, I came across this article to clear the codes. It is quite for these error codes to appear after having done a navigation update.
I followed this article for this code. It involves reading channel 15 in adaptions of the 5F unit and inputting a new code which you have to calculate using the tool on that page. Clear the fault codes at the end of the process.
For this one, you have enable the hidden green menu on your MMI system. there are many guides out there on how to do this using VCDS.
Once you're the in menu, do the following:
- go to car -- carmenuoperation
- change every value by adding "1"
- restart the MMI
- go into the hidden menu again
- change the values back to their original value, i.e. substract "1"
- restart the MMI
After that all your fault codes will be cleared.
Please note that despite these fault codes stored in the 5F unit, the funcitionality of the unit was not affected at all. I was just annoyed at seeing these error codes popping up all the time in my scans lol.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 2nd February 2018, 02:01 PM
My RS6 has the same non-faults, and it bugs me, even though they don't harm anything, I'll give this a go when I get a mo
