Old 2nd February 2018, 02:35 PM
A8Pete A8Pete is offline
Default Parking Brake Warning Light
I have a 2004 4.0ltr Diesel A8.
A working light for the Parking light has come on in the center dash display.
Im not familiar with he parking brake system. Any tips for establishing the cause of the dash light. Is this new rear calipers or parking brake switch?
Many thanks in advance
Old 28th February 2018, 10:45 AM
I have connected the VCDS and retrieved the error codes from the EPB module 053. It shows the control module as a fault but also bot motors and worn brake pads.
All brake pads were recently replaced and coded correctly
The left hand caliper and motor was also replaced recently.
If you all agree that the control module is the culprit does anyone have a link to the instructions for replacement and coding.
I understand that the module is beneath the battery. Is that correct.
Many thanksAddress 53: Parking Brake Labels: 4E0-910-801.clb
Control Module Part Number: 4E0 910 801 HW: 4E0 907 801
Component and/or Version: EPB A01H019 H01 0190
Software Coding: 0000431
Work Shop Code: WSC 20202 000 00000
VCID: DCBD0AA91F30269
5 Faults Found:
02431 - Right Parking Brake Motor (V283) Resistance to Movement
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 212896 km
Time Indication: 0
Date: 2018.02.05
Time: 19:49:34
Freeze Frame:
Voltage: 12.11 V
Count: 89
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 213912 km
Time Indication: 0
Date: 2018.02.25
Time: 15:40:32
Freeze Frame:
Voltage: 12.94 V
Count: 61
02430 - Left Parking Brake Motor (V282) Resistance to Movement
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 212896 km
Time Indication: 0
Date: 2018.02.05
Time: 19:49:34
Freeze Frame:
Voltage: 12.11 V
Count: 88
16347 - Control Module - EEPROM Error
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 4
Fault Frequency: 166
Mileage: 169736 km
Time Indication: 0
Date: 2012.12.11
Time: 10:07:07
Freeze Frame:
Voltage: 11.59 V
Count: 187
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 61
Mileage: 213888 km
Time Indication: 0
Date: 2018.02.25
Time: 15:18:08
Freeze Frame:
Voltage: 11.80 V
Count: 87
Old 28th February 2018, 11:21 AM
PDF technical dump for D3's is HERE on the forum and you should find full instructions on the relevant one
Old 28th February 2018, 03:02 PM
Many thanks. Will take a look.
Old 28th February 2018, 03:07 PM
Thats a great reference repository. Unfortunately there;s nothing I could find on the EPB module replacement and coding.
Does anyone know where I get see a 'how to' guide for replacing the EPB module and coding it in?
Old 28th February 2018, 04:01 PM
I can only speak for myself but I put all of my EPB issues down to nil use.
I just never use it. It auto-cycles about every 1000 miles but other than that, despite my friendly mech reminding me to use it, I just don’t. I put the auto in park and that is it.
I have had both sides lubed and freed off at least 3 times each in the 70k miles I have had the car and now the N/S has truly failed. It is beyond fixing so I am looking for replacement parts now. Euro parts out of stock.
So all my own fault really!
