Old 4th February 2018, 09:32 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Intake vacuum bellows on start up - video
Evening all,
I recorded the bellows on start up to check if they operate normally....however I’m not sure what I’m looking for.
Is the cold start from the video normal operation? They appear to move freely by hand when the engine is off as well. Do they move under throttle as well?
File Type: mov D0E09BC7-E862-459E-968A-422326391209.MOV (9.93 MB, 1544 views)
Old 4th February 2018, 09:37 PM
They look slow to me, mine close up instantly on starting.
Maybe you have a vacuum leak or the manifold flaps are not free to move?
They will move back out at fairly high revs - 3000+ IIRC?
Old 4th February 2018, 09:38 PM
That's exactly what they're supposed to do They don't move with the throttle, but at a specific rpm (can't remember), controlled by the ECU.
Old 4th February 2018, 10:51 PM
RICKY D's Avatar
Thanks both. I will ask the wife to record it whilst I give it some revs.
Do you have a video of some that you know operate normally for comparison?
