Old 15th March 2018, 02:44 PM
Leorio Leorio is offline
Default Disabling Touch Handle Sensor
After Auto-Scan I have this fault code:
Code:
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0G0315418
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58B5B80DEBE2FD8400-800C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
   XXXXXXXXXXX ELV                 XXXX
1 Fault Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 171
                    Mileage: 286336 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 13:38:32
Even if I clear it it comes back after a while. Fault seems valid - the outside door handle button is hard and stuck. Is it possible to disable there sensor somehow?
And if it is possible will the keyless entry still work? If you think about it if you disable only one sensor it should, right?
Any detailed info how to do this?
If needed there is full Auto Scan below. (I also have a question about other code, but I guess I should ask it in the different section).
And I know that I still haven't say hi and posted photos, will try to do it soon. I just had first off from work in two months and need to clean my beauty first and then will do proper introduction .
Code:
Thursday,15,March,2018,13:39:20:61846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ4E17N016208   License Plate: YS07SZT
Mileage: 177923mi   Repair Order: After Coding
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0F 15 16 17 18 19 1D 1E 25 34 36 37
          38 42 46 47 4F 52 53 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E17N016208   Mileage: 286340km-177923miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4E0 910 402 E    HW: 4E0 907 401 D
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H04---    Serial number: AUX3Z0G0315418
   Coding: 0311973
   Shop #: WSC 02629 005 00000
   VCID: 1E39EE15C94643B40A-804A
1 Fault Found:
004120 - Intake Manifold Runner (Bank 2)
               P1018 - 001 - Lower limit not reached
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 286348 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 13:29:13
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Voltage: 12.01 V
                    Duty Cycle: 20.5 %
                    Duty Cycle: 88.8 %
                    Duty Cycle: 20.5 %
Readiness: 0 0 1 1 1
Address 02: Auto Trans        Labels: 09L-927-760.lbl
   Part No SW: 4E1 910 156 Q    HW: 09L 927 156 A
   Component: AG6 09L 3,0 TDI RdW 0020
   Revision: --H01---    Serial number:        4281381
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 316325A9A8D8CCCCA7-8064
No fault code found.
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0008357
   Shop #: WSC 02313 000 00000
   VCID: 2241DAE5FD3E67542E-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Coding: 0412672
   Component: ELV                 XXXX
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 244DDCFDE72A69645C-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 300AG077578402
   Coding: 0000002
   Shop #: WSC 00000 000 00000
   VCID: 3A71028575AE0F9416-806E
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0040
   Subsystem 2 - Serial number: 00000000030289
   Subsystem 3 - Serial number: 0102.02.070000000100010037˙
   Subsystem 4 - Serial number: 010037˙
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000113759
   Coding: 0018467
   VCID: 1C3DE41DDF5A51A4E4-8048
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0103121
   VCID: 366916B541B6EBF4F2-8062
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 01719111
   Shop #: WSC 02313
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276V7800834
   Coding: 0000001
   Shop #: WSC 00196 210 83196
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H14 4210
   Revision: 91H14421    Serial number: 0037P0G07R43
   Coding: 0431707
   VCID: 2757CBF1961C827C79-8072
   Subsystem 1 - Serial number: 63328RB4020ABB67P
   Subsystem 2 - Serial number: 63428RB4020ABB51J
   Subsystem 3 - Serial number: 63528RB4020ABBB2R
   Subsystem 4 - Serial number: 63628RB4020ABBC2T
   Subsystem 5 - Serial number: 63729RB401E55D2AX
   Subsystem 6 - Serial number: 63829RB401E55B78Z
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112041
   VCID: 65CB81F9AC90506C8B-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 B    HW: 4E0 920 951 B
   Component: KOMBIINSTR. VDO H82 0530
   Revision: D04         Serial number: AUDID3G1000984
   Coding: 0000403
   Shop #: WSC 00196 067 57207
Address 18: Aux. Heat        Labels: None
   Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
   Component: Heizgeraet      H08 0140
   Revision: 0000000C    Serial number: 00000009013887
   Coding: 0000011
   VCID: 1A31E205D56E2F94F6-804E
2 Faults Found:
02245 - Connection; RF Remote Control
            004 - No Signal/Communication
01408 - Under-Voltage Shut-Off (fixed Value)
            000 -  -
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H11 0090
   Revision: 11          Serial number: 2000306B098099
   Coding: FCFF5BDE2B7D04
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 26062008195458
   VCID: 1F47D311CE4C4ABC01-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0390
   Revision: 00044000    Serial number: AUZ5ZBG3150517
   Coding: 0412672
   Component: ELV                 XXXX
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 171
                    Mileage: 286336 km
                    Time Indication: 0
                    Date: 2018.03.15
                    Time: 13:38:32
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0013310
   VCID: 2855C8CD9B028D0470-807C
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063342
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364BQ077635407
   Shop #: WSC 00732 210 88528
   VCID: 3B7F07817A94369C0D-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000701600008
   Coding: 0036036
   VCID: 1D3BE919C44058AC13-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0032622
   VCID: 2045D0EDF332754438-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H08 0020
   Revision: 00200008    Serial number:  W040701300519
   Coding: 0004317
   VCID: 2A5132C5850EBF1466-807E
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H03 0120
   Revision: PROD_01     Serial number: 00000000001934
   Coding: 0000023
   VCID: 2C5D34DD8FFAA12494-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000103581
   Coding: 0010001
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0032262
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000221
   Shop #: WSC 00294 210 01865
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396BZ077559253
   Coding: 0000001
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H06000    Serial number: 76300800243101
   Coding: 0000003
   VCID: 254BC1F9EC10906C4B-8070
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000000689
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  2702080133
   Coding: 344530393135313035412056413032373032303830313333
   Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0039246
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000702020245
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0039246
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720701801032
   Coding: 0301008
   VCID: 234FDFE1E2246E5C25-8076
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H18 1130
   Revision: 00000000    Serial number: 00000005143083
   Coding: 0010900
   Shop #: WSC 00196 210 90060
End-------------------------(Elapsed Time: 03:53)--------------------------
