Thread Tools
Display Modes
Hi There,
Just fitting a new coolant tank and then re-fitting the under tray after draining and i was looking if you could access the front parking sensors easily (you can't) and notice that my belt has a slit it it. It's reasonably small atm and along the belt ( if it goes i'd have two belts about 1/3 and 2/3 width). At first it was a minor panic as I was worried it was the timing belt, but it it isn't and that's a toothed belt which makes far more sense. However i'm now researching how to replace as loosing things like the alternator and power steering would be a royal pain etc. Anyone know much??? I'd prefer not to have to take the front end off for example. Did one on my jeep with a bit of swearing and wiggling of things, though that had a little more space and less AUDI ideas of lets take the whole car apart for an o-ring and charge the customer thousands ![]() Ta, Lee
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
