Old 12th April 2018, 06:44 AM
neeldub neeldub is offline
Default Battery Energy Management Module Shut off stages
Hey guys I came across the following information while using ODIS in regards to the different shut off stages of the battery.
If you find error messages such as the following:
Quiescent Current Stage 1, Stage 2, Stage 3, Stage 5 & 6 ,here's the description below for the different stages.
In shut-off stage 1 the following functions are restricted or inactive:
Restricted functions:
- Window lifters
- Interior lighting
- Boot lighting
- Reading lights
- Roller blind
- Sun roof control
- Seat adjusters (manual)
- Boot power latch
Inactive functions:
- Ambient lighting
- Coming Home
- Main beam
- Footwell lighting
- Interior mirror
- Air conditioner
- Leaving Home
- Proximity sensors (for
- Fog lights
- Headlight washer system
- Mirror fold function
- Mirror heating
- Daylight driving lights
- Washer fluid heating
- Exterior door handle illumination
- Door power latches
Quiescent Current Stage 2
In shut-off stage 2 the following functions are restricted or inactive:
- Window lifters
- Radio clock
- Reading lights
- Sun roof control
- Boot power latch
Inactive functions:
- All infotainment components except telematics
- Ambient lighting
- Coming Home
- Main beam
- Footwell lighting
- Interior lighting
- Interior mirror
- Air conditioner
- Boot lighting
- Leaving Home
- MMI open/close manual
- Fog lights
- Tyre pressure monitor receiver
- Roller blind
- Mirror heating
Quiescent Current Stage 3
In shut-off stage 3 the following functions are restricted or inactive:
- Radio clock
- Reading lights
- Sun roof control
Inactive functions:
- Ambient lighting
- Coming Home
- Window lifters
- Main beam
- Fingerprint functions
- Radio remote control
- Footwell lighting
- Interior lighting
- Interior mirror
- Air conditioner
- Boot lighting
- Leaving Home
- Fog lights
- Roller blind
- Mirror heating
- Power latching
Quiescent Current Stage 5
Shut-off stage for auxiliary heater (shut-off stage 5):
If this shut-off stage is activated the auxiliary heater is subject to the following restriction:
Fans and glow plugs remain in operation for max. 1 hour.
As shut-off stage 5 is only set when shut-off stages 1 and 2 have been passed, all
consumer restrictions entailed by stages 1 and 2 are also active.
Quiescent Current Stage 6
Shut-off stage 6:
Shut-off stage 6 ensures that the control units only remain "awake" briefly below a specific
battery charge level. This function is only activated in response to so-called wake-up events
(such as a door handle being turned) for the CAN/Most bus.
I hope some of you find this information useful..
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 12th April 2018, 08:28 AM
Furthermore, VCDS can extract history from the BEM module and additionally VCDSToolbox can be used to read the data file. You get more information with the 'C' revision module using software 550 on the D3 than the earlier modules.
Matt
