Thread Tools
Display Modes
Today I mostly did a door mirror swap. When I got the project 8 they only significant body damage visible was a smashed drivers side mirror and housing. I had either to order a new one from Audi, wait for one the same colour to come into A8 parts or upgrade. As I know we all like upgrades I thought a nice pair of S8 mirrors with an added twist; but that’s another how to!
This one is how to swap your door mirror housing over. In the picture are the broken mirror and housing and the pair of cast aluminium housings. You may notice that one housing is shinier than the other, but that is another how-to. So it starts with dismantling the old door mirror. Underneath there is a plate with 2 screws to remove. Remove them and wiggle the plate clear. Once the plate is off you can remove the mirror by pushing it from behind from the edge nearest the door. I got it wrong and broke the mounting ring the mirror push fits to on the passenger side. Although I didn’t break the mirror. ![]() Once the mirror is out you will have this Except you will have the ring and small white piece still attached. The ring can be refitted, the rocker arm I had snapped and did a temp repair with araldite; I hope it holds! Remove the 3 circled screws and the housing can be removed. Below, the red line highlights a lug that caused a small problem. It is ‘T’ shaped and as you can see in the photos: You can just see below that the plastic cover is ‘T’ shaped and the Aluminium cover is ‘L’. Initially I was going to mod the Ali cover. Then I decided to mod the lug. Using some square nose pliers: I snapped off the appropriate side of the ‘T’. Note that you need to make sure you take of the excess metal all the way down and you may have to file the top of the 'L' to allow the cover to sit flush with the mirror mounting. Once this was done the Ali covers fitted straight on. Assemble is the reverse of removal as they say. ![]()
Top write-up mike! ... and they look brilliant too
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group |
Yes good write up..could have done with this last week,,,changed mine to shiney silver ones as well..As im a poser trying to pose..
![]() Quote:
P.S. I did it last week! ![]()
