Old 25th April 2018, 12:41 PM
Default 3G AMI Port
Quick question.
Can anyone tell me (with a photo preferably) where the AMI port would be on a 3G A8.....
I've been asked the question, and its stumped me !
Old 25th April 2018, 01:01 PM
Just guessing, but hidden in the glove box like other 3G Audi's?
Matt
Old 25th April 2018, 01:05 PM
I guessed the same based on my RS6, but the D4 has it under the centre arm rest so was looking for definitive preferably !
Old 25th April 2018, 01:32 PM
I can't help any further except that it's hidden well! There's a part number for the trim piece called 'dash panel box', item 2 in the picture and that the cable is only 850mm.
Sorry can't be definitive.
Matt
Old 25th April 2018, 03:13 PM
Lee S Lee S is offline
Definitively on my 2009 3G D3, it was in the glove-box on the rear, upper right hand side wall.
Lee
2017 Nissan Leaf Tekna
Old 26th April 2018, 05:46 PM
It hasn't got one.
The manual says it will be in the glovebox (if it has AMI).
Nowt there.
I intend to stream my Spotify subscription from my mobile to the head unit, as I can do in the Surf.
Turns out I need to lose the CD changer (which I would never use, or the DVD/SD/JukeBox) and replace it with either:
Part 4E0057785F (no longer listed on TPS, so it's ebay etc. - I have already been gifted a BT <> AMI lead)
OR
Go with something like a Dension 500 BT which emulates the changer.
Happy to be given advice re: best choice
Old 27th April 2018, 11:59 AM
Mine had the CD Changer and the DVD player with SD card slots AND the AMI port and they all worked too. No idea why you'd need to lose one of the disc players....
Lee
Old 27th April 2018, 12:36 PM
You need to take one of their feeds into the MMI, then either using the Audi part, give it up to an AMI socket on the end of a cable, or with the Dension, emulating the CD changer with a Bluetooth feed.
Old 27th April 2018, 01:09 PM
I thought that a splitter was used so that you can retain the equipment that was already there. That's how it works with my 2G MMI and AMI
