Old 23rd May 2018, 07:44 PM
homer simpson's Avatar
Default Help with some D3 S8 error codes
Hi all, I went to see a lovely S8 today and I am very close to pulling the trigger. The seller (trade) was happy for me to do a scan and left me to it so i did after a test drive. The car drove beautifully and all the electrics work bar the button on the driver's door (lock) handle. Are these anything to worry about or any expensive to fix? The parking brake fault for the rear sensor I am hoping is a wear sensor as the car has ceramics!
Any help appreciated
1. 005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
2. 02596 - Rear Brake Pads Worn
008 - Implausible Signal
3. 006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Code:
Gateway Installation List: 4L0 910 468 A
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Code:
Fault Codes have been Erased
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148321 km
Time Indication: 0
Date: 2018.05.23
Time: 15:13:13
Freeze Frame:
RPM: 640 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 102.0°C
Temperature: 66.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.954 V
Readiness: 0110 1101
Code:
Address 01: 1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148321 km
Time Indication: 0
Date: 2018.05.23
Time: 15:14:51
Freeze Frame:
RPM: 639 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 67.0°C
Voltage: 13.208 V
Address 11: 1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148321 km
Time Indication: 0
Date: 2018.05.23
Time: 15:14:49
Code:
1 Fault Found:
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 133232 km
Time Indication: 0
Date: 2015.09.24
Time: 00:02:20
Freeze Frame:
Voltage: 10.46 V
Count: 61
Old 24th May 2018, 07:35 PM
richardracer richardracer is offline
Default D3 S8 error codes
Hi there,
I had 2 of those error codes on my D3 S8, namely engine mounting and ecu code. Neither changed or had an effect for over 100,000 miles. Rear pads easy to check, remove rear wheel and look.
Regards
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 25th May 2018, 02:30 PM
The Active engine mounting soloniods are not working on most D3's and most people ignore them due to stupid cost and time consuming job to replace them
Old 25th May 2018, 06:54 PM
Originally Posted by richardracer View Post
Hi there,
Regards
Richardracer
That's reassuring! Can ceramics be checked in the same way?
That's good news. Will try and get the mount checked to ensure it's not shot and if it's ok leave it alone
